Work instructions clearly state tap to depth, the fitter had tapped 3 of the 4 holes, for some reason he missed one, maybe distracted or something personal could be on his mind, he is also a time served bench fitter with 30 years experience hardly think he needs re training. He has tapped 100s of these the same way with no problems. ?????I am not convince in factoring "operator equation" for an error. Work Instructions and effectiveness of training in the use of work instructions may have to be investigated.
For thirty years or more I've been using the excuse,Work instructions clearly state tap to depth, the fitter had tapped 3 of the 4 holes, for some reason he missed one, maybe distracted or something personal could be on his mind, he is also a time served bench fitter with 30 years experience hardly think he needs re training. He has tapped 100s of these the same way with no problems. ?????
So if you or anyone can come up with a better reason, I'm all ears.
Insp 2s
Insp 2s
I do have an open mind. But on this particular component 3 of the 4 holes were tapped to depth, therefore drawing/procedures/work instructions were followed.As long as you believe that there is not other answer, you will never find another answer.
When I was vacationing in Britain a few years ago I was lamenting about the problems I was encountering while driving "on the wrong side of the road". The person I was lamenting to suggested that as long as I believed I was driving on the wrong side of the road I would continue to have problems.
That opened my mind. You need to open yours.
I've been in the same position as the OP, wherein a customer found a single nonconforming item out of tens of thousands that had been previously produced, and for which no assignable cause could be found, but CA was still demanded. The only way to explain the thing was that someone, at some point, put a nonconforming item in with the conforming ones. A pure case not only of human error (if we dismiss the idea that it was done deliberately, and there was no reason to think that was the case), but of an obvious outlier for which corrective action was neither possible nor sensible.
Ironically, the beseeching of the OP to be open-minded is coming from a position of closed-mindedness, with the closure occurring due to the misbegotten idea that all nonconformities are amenable to, and worthy of, corrective action.
Sometimes customers unwittingly demand creative CA reports, and in those cases you sometimes have to give them what they ask for. They're not asking for corrective action, per se, but rather a response that will allow them to close the issue and get on with making other things worse.
Good point Jim, and Somasheker too.
My remark came off harsher than intended. All I meant is that one needs to make a diligent effort to resolve such things, and that our own frame of mind can hinder that process.
Specifically on Jim's topic. I feel that so much has been made of Deming's saying on this topic that it is always the fault of the system and never the fault of a person is often taken too far. As a result, "human error" is seldom accepted by certification bodies and as a result, customers.
As long as our industry has to deal with this thinking, we will be challenged to find a different answer. I'm not suggesting lying. I'm suggesting getting past the thought that it has to be "human error". Until you do, you will not find an acceptable answer.
This thread has suggested several ways to improve the process, and deeper consideration of them may get you past "human error".
I think we are aware the true situation OP faces is developing a corrective action for a root cause when the customer (and "some" of the Cove writers) refuse to believe an operator "distraction" was the sole cause.:truce: Peace :truce: Peace :truce: peace ...
This thread has been going good so far and has brought ideas at various levels. Again, lets focus on the issue of inspector 2s, by getting into his shoe and under his cap, rather than getting into the personality.
:truce: Peace again ~~~
