Eccentricity of a Profile Projector
E
etdiyas
eccentricity of profile projector
can anyone help me in determining the eccentricity of profile projector, and what standards are required for this method. We calibrate our profile projector using a standard glass scale and only the x and y axis are being compared with the standard.
hope anyone could help me on this.thanks
David Mullins
Hmmmm
Isn't the profile projector 2 dimensional, therefore you only need to check x & y?
Ryan Wilde
There are two tests that I can think of that might be known as eccentricity in a profile projector, and since I don't know which one you mean, I'll address both. If you mean something entirely different, please describe it and I'll let you know.
MAGNIFICATION ECCENTRICITY:
The most common method that I have seen used for eccentricity is through the use of either a calibrated gage pin or gage ball. Magnification accuracy is checked in the center of the screen, using the glass scale. The stage of the projecter is then moved to place the ball or pin at the edges of the screen in each of the four quadrants (right, left, top, and bottom, or upper right, lower right, upper left, and lower left - I've seen both methods employed). The magnification error found at the center position is compared to the error at all other positions. Make sure you check both X and Y axes for magnification in each point.
If the error is excessive, but linear, the error can be adjusted out. For example, right is low, middle is nominal, left is high. By readjusting the angle of the internal mirror (it's no fun, trust me) you can remove this error. If the error is excessive and nonlinear, you just bought yourself a three thousand dollar mirror, because your's is warped.
COMPASS ECCENTRICITY:
This one requires very specialized tooling to check. Get a nail (a roofing nail works nicely because of the broad head) and make sure the point is very sharp. Position the nail in the center of the screen, so that the point is exactly in the center. Slowly rotate the compass (screen) and ensure that the point stays in the center. If there is any deviation from center, then find the worst deviation, measure its magnitude using the x-y stage, rotate the compass 180°, and measure the deviation directly opposite. Take the mathematical difference, divide by two, and you have your compass eccentricity.
To adjust compass eccentricity you have to loosen the three or four screws that retain the compass and reposition the screen. On some models the retaining screws merely hold an offset screen retainer, so you would loosen the screws and rotate the retainers to set the proper position. Be careful not to rotate the screen in the frame, as this will alter your zero compass reading.
That's it for now,
Ryan
E
etdiyas
david,
you are right, but the problem is this when our supplier calibrated one of our profile projector their results has an "eccentricity of center of cross line on screen at rotation". And that was the problem i observed in the other projector when i calibrated it using our procedure (x and y axis) and unfortunately i don't know what is the procedure and standards for this.
E
etdiyas
ryan,
the compass eccentricity could be the problem that we are encountering right now on our profile projectors. And thus the nail would be the best tool i can use? Can i use the cross hair glass as a tool?
the problem i observed was this, when the cross hair glass was put on the stage and centered on the screen and when i moved the x axis to the right the line of the scale seems rising same with the y axis but whe i rotated the compass (357º7' reading on the vernier) the problem perhaps was eliminated. Hope you got my point.
thanks
metrologyguy
I am not sure of your problem but, if you are trying to quantify "Z" error I have a suggestion. Using your reticle (glass I hope) you could position it on top of two 2" or 4' gage blocks. Take a reading and record the results. Remove the gage blocks and place the reticle on the comparator table. You would need to have a small angle plate or something else square to assure you are placing the reticle in the same location on the table that it was in for the 4" reading. Then using only the Z adjustment focus on the same mark on the reticle, take a reading.
If the Z axis is properly aligned, there should not be any significant error.
I hope that was the question you were asking.
Ryan Wilde
Originally posted by etdiyas
ryan,
thanks
It sounds as if you have two problems, both of which are fixed at the same time.
First problem:
The "eccentricity of center of cross line on screen at rotation" means that the crosshair on your projector screen is (or was) not in the phsical center of the compass rotation. Basically, your glass was not centered in its frame. Using the cams or retainers or whatever you have, it needs to be centered.
Second problem:
From your description, it sounds as though your compass and screen are not aligned with your stage. If the compass has enough adjustment (probably not - there is very little adjustment on the compass) then you can use that, which is simple. I use a nail, you can use the crosshair if you like. I'll describe the adjustment the more difficult method, which is probably the method you will have to use. Set the compass to zero, and position your crosshair at either the far left or far right of the screen. Move your x-axis to place the crosshair at the opposite side of the screen without disturbing the crosshair on the stage. If the crosshair doesn't stay on the horizontal screen line, then loosen the screen and rotate it 1/2 of the error, keeping the compass at zero. Repeat the above steps until the compass at zero agrees with the x-axis motion. This may impact your eccentricity, and you will have to adjust for both at the same time. After you do it a few times, it gets to be fairly easy, but it will take you some time the first time.
Hope that this makes sense,
Ryan
R Maximum allowed eccentricity for any shaft or hole diameter Misc. Quality Assurance and Business Systems Related Topics 7
A Linearity and Eccentricity Point Definitions - Ref: ISO/IEC 17025:2005 ISO 17025 related Discussions 1
S Explanation of Concentricity and Eccentricity Inspection, Prints (Drawings), Testing, Sampling and Related Topics 19
T Capability calculation of surface profile Capability, Accuracy and Stability - Processes, Machines, etc. 20
K COPLANARITY: Composite profile tolerance on multiple surfaces- what does" lower dimensional reference frame tolerance" control? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
W Surface Profile All-Around AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
I Profile tolerance with a positional tolerance to a hole ? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Brizilla User Profile - How do I edit my profile info? Elsmar Xenforo Forum Software Instructions and Help 3
I Lifetime Support Calculation - Thermal Operating Profile Reliability Analysis - Predictions, Testing and Standards 7
M How to verify profile gages provided by customer General Measurement Device and Calibration Topics 5
E Department Plan for QA and HSE (profile, plans, structure, goals, etc.) Misc. Quality Assurance and Business Systems Related Topics 2
G Gear Profile & Lead Report Manufacturing and Related Processes 1
P Romer Arm - Profile of a Surface Changing General Measurement Device and Calibration Topics 4
R Reporting Profile of a surface with U modifier Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
B Profile of a Surface Callout on this Drawing General Measurement Device and Calibration Topics 4
O Can a Profile of a Surface have a Diameter Symbol? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
R Temperature Profile for Transport Simulation (Sterile Eye Drops) Other Medical Device Related Standards 1
P Profile Tolerance and CPK Manufacturing and Related Processes 3
K Can a Surface of a profile be applied to a feature of size? GD&T questions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Q Form IPC 1720A Assembly Qualification Profile still required? Various Other Specifications, Standards, and related Requirements 1
J Profile of Surface with Basics and Angle Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
B Requirement to have Customer Signature Profile on File Document Control Systems, Procedures, Forms and Templates 7
T CMM Inspection of Profile Tolerance Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
M Measuring a circle's profile Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
C Complex Surface Profile as a datum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
D Profile of a Line of a radius of 25mm basic dimension - Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Surface Profile and True Position Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
R Capability for CMM Scanned Profiles on a feature with a Bilateral Profile Tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 26
C Inspecting a Profile Tolerance for a Die Cut Gasket Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
K Profile of a Surface Tolerance - Part with a 195 mm radius on it Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
S Surface Profile of a Hole - The meaning of the tolerance in the provided drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
AnaMariaVR2 A Profile of the Pharmaceutical Manufacturing Industry: Russia Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
B Surface Profile Callouts - How the profiles are being dimensioned Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
C I need to verify the surface profile of a part - Sine plates General Measurement Device and Calibration Topics 4
optomist1 Contour vs. Profile - Is there a connection between "Contour" & "Profile"? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
optomist1 Composite Profile Tolerancing Clarification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 21
optomist1 ASME GD&T Certification Test - Converting Coordinate Tolerances to Profile Tolerances Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
optomist1 Profile of a Surface - Applying Profile of a Surface Geometric Control Symbols Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
A Customer Profiles - Creating a Customer 'Profile' for our Top 10 Customers Document Control Systems, Procedures, Forms and Templates 2
B Measuring the Profile of a Surface Inspection, Prints (Drawings), Testing, Sampling and Related Topics 19
C Reporting Profile of a Surface Results on an Internal Cylindrical Feature Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J Reputable Third Party Inspection (Metrology Lab) In USA? Cam Profile Measurement General Measurement Device and Calibration Topics 5
P ISO 20072 Requirements - Example or template of a DFP (device functionality profile) Other Medical Device Related Standards 2
O How to report Profile of a Sphere crossed by a Hole Inspection, Prints (Drawings), Testing, Sampling and Related Topics 31
A Capability Studies for Profile (GD&T Callout) Capability, Accuracy and Stability - Processes, Machines, etc. 6
M Changing Job Profile - Logistics Engineer to Buyer Career and Occupation Discussions 3
S Benchmarking PVC Profile Extrusion Metrics Benchmarking 2
G How to calculate profile of a surface? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
CycleMike Profile of datum planes - Profile callout back to datum A (itself) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Angularity or Composite profile - Angularity callout on a recent print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
