apestate
I would like to start a elementary thread intended to help solidify the concepts of ISO 9000 management in the mind of the novice.
My mind.
I am implementing ISO 9000 in a screw machine shop of 15 employees. One of our largest customers is a manufacturer of filtration systems, so we cut them hydraulic pistons, retainers, pins, fittings, needles, spacers, and so forth. These parts go into filtration devices that go into automotive applications, and our customer is pursuing TS16949.
This shop is disorganized. An ISO 9002 based system was put into use at one time, but the coordinator was fired for misconduct. After that, with no enforcement, and no encouragement, the system went lax.
I don't know how much I'm getting from these procedures. They are written poorly, and instructions are mixed with policy and what should be in the procedure itself.
I have some very basic questions regarding things that probably seem intuitive to the most of you.
1) We do not control set up information. What level of control do machine setup procedures need to exercise? I'm sure it doesn't have to be step by step, but I'm sure any changes to the information needs to go through a defined procedure and the proper authority. Is this correct?
2) How many procedures should I record? Should I cover everything addressed in the '94 standard?
3) How do I use procedures in the overall process?
4) How could I gain access to a successful and proper documentation system to get meaningful insight into how this thing is actually done, or done well?
5) Our customer is TS16949, and they have mandated that we become certified to ISO 9001. In the future, do you expect any requirements will be mandated that will require another effort of this scale? We're doing SPC, FMEA, APQP and PPAP, I have the standards for those and the standard for MSA. That's not a problem. If, however, for any reason a customer mandated TS16949 for this 15 person lo-tech shop, I don't see us providing parts to that customer. Is this a possibility?
Anyway, I think I'm making good progress and I'm ready to start releasing some of the procedures that are relevant on a day to day basis. I have plenty of work to do, and I'm thankful for this forum. Apparently, this is the best resource on the internet. I hope I'm not asking to use it in a manner that was unintended.
--Erik
My mind.
--Erik
